Travel & transport from BBC stories as at 13:55 28 Apr 2025
- One dead and multiple injured after hit-and-run boat crash in Florida
28th Apr (1996)
14:09 Reading to Newbury
14:12 Newbury to Reading
15:10 Newbury to Reading
15:10 Reading to Newbury
16:05 Newbury to Reading
12:35 London Paddington to Exeter St Davids
13:05 London Paddington to Newbury
16:31 Barnstaple to Axminster
April 28, 2025, 13:55:41 *
[109] Chiltern Railways: an update on rolling stock / services
[96] Driving tests - ongoing discussion
[46] Stop orders as cover for cancelled services
[41] Doublebagging, Rawdoggers, Barebackers
[38] Priority seats redesigned for London transport - April 2025
[36] Nantwich footbridge to be restored, not replaced - Network rai...
Author Topic: Inspector Sands, and a code 3 on platform 1.  (Read 5249 times)
« on: January 13, 2016, 16:04:38 »
From The Independent
if you've ever wondered what the person on the London Underground tannoy was talking about when they referred to "Inspector Sands", be comforted by the fact that you are definitely not alone.
The numbered codes are for cleaning staff, and are used by station announcers to direct them to mess.
However, it is important to note that while "Inspector Sands" is the same for every single station, 1-6 are cleaning codes and are not necessarily used in the same order across the network
Here are the codes and what they mean:
Code 1: Blood
Code 2: Urine/Faeces
Code 3: Vomit
Code 4: Spillage
Code 5: Broken glass
Code 6: Litter
Code 7: Anything not fitting these categories (the mind boggles)
Inspector Sands: A fire alarm has been operated and staff have two minutes to come to the control room - if they don't check it automatically evacuates the station.
« Reply #1 on: January 13, 2016, 16:08:14 »
It's when you're on the mainline platforms and you hear an announcement for "a code F3 on platform 2" that you start to worry...
« Reply #2 on: January 13, 2016, 16:27:17 »
Would that mean that they've accidentally allowed [no names, no pack drill] through the gateline despite his being in possession of a valid ticket?
« Reply #3 on: January 13, 2016, 16:32:48 »
After Inspector Sands had done his rounds last week at Paddington, someone left a microphone on. All over the station could be heard muffled conversations and the horrible scraping noise that comes from a flexible microphone being moved about. Very grating. Particularly in the normally serene surroundings of the Victorian 1st Class Lounge.
« Last Edit: January 13, 2016, 16:50:44 by bignosemac » Logged
Ollie
« Reply #4 on: January 13, 2016, 18:04:05 »
If you hear this it's *usually* safe to assume that the system is broken and they can't reset it. So they put the mic on which overrides the evacuation announcement.
« Reply #5 on: January 13, 2016, 18:32:38 »
Aha. That explains why Inspector Sands was so hard to find. The test went on far longer than normal.
Couldn't the volume on the microphone have been turned down?
Ollie
« Reply #6 on: January 13, 2016, 18:58:03 »
Not sure on that one, I have a feeling it can't be changed on that one as it's the mic that's linked with system for evacuation purposes - but really not 100% on that.
« Reply #7 on: April 17, 2017, 09:28:01 »
Reminded of this thread on Wednesday at King's Cross ... "Platform 3, code 2".   Confusing of course, as that could be no. 1 or no. 2 as they're referred to in family ...
« Reply #8 on: April 17, 2017, 09:39:58 »
Sure that wasn't a cleaner's or security announcement? Code to advise them what the (type of) problem is?
« Reply #9 on: April 17, 2017, 09:42:27 »
Was a call for "duty contract cleaner".   "Code 2" is Urine or Faeces in railway terms
« Reply #10 on: April 17, 2017, 13:33:39 »
At Bristol Airport, a tannoy announcement for "someone from extension 286" used to be a call for Special Branch.
