No recent travel & transport from BBC stories as at 17:55 28 Apr 2025
28th Apr (1996)
16:47 Bristol Temple Meads to Warminster
17:30 Warminster to Bristol Temple Meads
17:49 Reading to Gatwick Airport
18:06 Reading to Newbury
18:08 London Paddington to Frome
18:43 Bristol Temple Meads to Westbury
18:48 Newbury to Reading
19:06 London Paddington to Bedwyn
19:13 Salisbury to Bristol Temple Meads
19:29 Gatwick Airport to Reading
15:10 Gloucester to Weymouth
16:21 Reading to Gatwick Airport
16:31 Barnstaple to Axminster
17:01 Severn Beach to Salisbury
17:28 Weymouth to Bristol Temple Meads
17:36 London Paddington to Plymouth
18:00 Newbury to London Paddington
18:27 Newbury to London Paddington
15:42 Exeter St Davids to London Paddington
April 28, 2025, 17:58:11 *
[143] Chiltern Railways: an update on rolling stock / services
[80] Driving licences and tests - ongoing discussion, merged topics
[49] North Cotswold line - driver route knowledge
[38] Stop orders as cover for cancelled services
[34] Doublebagging, Rawdoggers, Barebackers
Author Topic: Thames Turbo Air Con.  (Read 7441 times)
a-driver
« on: May 03, 2015, 09:00:27 »
Following some protracted contract negotiations between the installers/maintainers of the current system an agreement has been reached whereby the contract to maintain the air con units has either been terminated or an agreement for further work has been agreed, either way, 166218 has been sent away and has had its air con system stripped out and replaced.  Other units are being sent away to have this work carried out with at least one away from the area presently having the work carried out.
Will be interesting to see the results.... or feel.... the results of this work!
« Reply #1 on: May 03, 2015, 09:37:44 »
There were reports of this unit being seen on the Honeybourne-Marston branch...so guess the works are being done at the Priors Long Marston yard
« Last Edit: May 03, 2015, 10:49:29 by ChrisB » Logged
« Reply #2 on: May 03, 2015, 10:09:28 »
Yes, Long Marsden is where the work is taking place. The saga continues!
Thatcham Crossing
« Reply #3 on: May 03, 2015, 10:12:53 »
Never seems to work very well and resulted in me nearly getting a soaking last year, when train decelerated and a cascade of water came out of the roof into the vestibule - it wasn't even that warm a day.
« Reply #4 on: May 03, 2015, 10:56:44 »
Never seemed to work very well, although that may be as much due to people opening all the windows as much as anything else.
a-driver
« Reply #5 on: May 03, 2015, 12:05:28 »
The windows should all be locked after the current installers/maintainers claimed the air con units themselves worked fine, the failures were being caused by the windows being opened.  The depot locked the windows put the ball back in their court for the next move!
It was maybe two years they had a management meeting with the contractors.  The two management teams went round a set that was signed off days before as being a ok.  They opened up the vents and found them clogged with dead leaves!
« Reply #6 on: May 03, 2015, 16:47:24 »
I will look out for open windows!
chrisr_75
« Reply #7 on: May 03, 2015, 18:28:59 »
Are you getting your types of Turbo's confused? I believe one has no aircon and opening windows, the other type has aircon and lockable windows which are usually only opened in the instance of an A/C failure. I'm sure someone with better knowledge will correct me if I'm wrong!
« Reply #8 on: May 03, 2015, 18:34:35 »
Yes, you are correct. The 166s have aircon/lockable windows, the 165s (majority) don't haveeither.
