No recent travel & transport from BBC stories as at 08:35 27 Apr 2025
08:58 Great Malvern to London Paddington
09:15 Bristol Temple Meads to Weston-Super-Mare
10:10 Weston-Super-Mare to Severn Beach
13:30 Bristol Temple Meads to Westbury
14:35 Severn Beach to Weston-Super-Mare
14:40 Westbury to Bristol Temple Meads
21:00 Bristol Temple Meads to Avonmouth
21:28 Avonmouth to Bristol Temple Meads
22:06 Portsmouth Harbour to Westbury
08:00 Bristol Temple Meads to Penzance
11:35 Severn Beach to Weston-Super-Mare
14:07 London Paddington to Cardiff Central
14:10 Portsmouth Harbour to Cardiff Central
14:50 Penzance to Exeter St Davids
15:10 Weston-Super-Mare to Severn Beach
16:08 Weston-Super-Mare to Severn Beach
16:10 Portsmouth Harbour to Cardiff Central
16:48 Bristol Temple Meads to Castle Cary
19:10 Portsmouth Harbour to Cardiff Central
An additional train service has been planned to operate as shown 09:25 Exeter St Davids to Penzance
April 27, 2025, 08:49:18 *
[100] Penryn to Melksham - summary and some pictures from 25.4.2025
[90] Standardisation of Time and the Railway Clearing House
[56] Solar power between the lines
[50] Intoxicated person plan needed on Tube - coroner, April 2025
[49] Weymouth - station, facilities, improvements, events and incid...
Pages: 1 ... 3 4 [5]
Author Topic: Train hits fallen signal between Reading and Newbury - 17 November 2014  (Read 48440 times)
« Reply #60 on: March 31, 2015, 15:09:27 »
....err, here is another one to add to the list (Cantley, Sunday 29 March 2015).  Think the RAIB (Rail Accident Investigation Branch) might be extending their investigation a bit Roll Eyes Undecided Shocked
« Last Edit: March 31, 2015, 18:12:46 by SandTEngineer » Logged
« Reply #61 on: March 31, 2015, 18:39:28 »
Is that what the S & T call a lower quadrant  Grin
I can see a whole load of ultrasonic testing and or cctv being done to quite a number of hollow tubular signal posts
« Reply #62 on: March 31, 2015, 20:34:35 »
Does this count as NFN. (Normal for Norfolk!)
« Reply #63 on: April 01, 2015, 11:24:13 »
In my time in S&T (Signalling and Telegraph) maintenance you hit the post with a hammer.  If your ears rang and you got covered in bird poo you knew the post was OK.  If the hammer made a big hole and you got covered in rust and flaking paint you knew you were in (big) trouble  Roll Eyes Tongue Grin
« Last Edit: April 01, 2015, 19:56:59 by SandTEngineer » Logged
« Reply #64 on: April 02, 2015, 20:41:41 »
I used a similar approach in testing window panes, until the glazier I worked for went bust.
« Reply #65 on: April 02, 2015, 22:21:52 »
But you had a smashing time until then.  Grin
« Reply #66 on: April 02, 2015, 23:07:33 »
I reckon that was the work of badgers - look how they've tried to hide the result of their excavations.  Wink Cheesy Grin
« Reply #67 on: September 23, 2015, 13:05:00 »
Corroded signal post apparently
http://www.itv.com/news/meridian/update/2015-09-23/train-crash-caused-by-corroded-signal-post/
« Reply #68 on: September 23, 2015, 13:55:52 »
Full RAIB (Rail Accident Investigation Branch) report here
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/462405/R152015_150923_Newbury.pdf
« Reply #69 on: September 23, 2015, 20:10:36 »
Purely for completeness in this topic, here is the summary from that Rail Accident Investigation Branch (RAIB (Rail Accident Investigation Branch)) report:
Summary
At about 14:35 hrs on Monday 17 November 2014, a train travelling at 110 mph (177 km/h) struck the top of a signal which had collapsed and fallen across the railway line near Newbury. The signal post completely obstructed one track and partially obstructed a second (the one on which the train was travelling). There were no injuries and the train did not derail, but it did sustain some exterior damage. The outcome could have been much more serious if the first train to encounter the signal had been travelling at speed on the line that the signal had completely obstructed.
The signal collapsed because the base of the post, which was of hollow tubular steel construction, had corroded through, causing an almost complete loss of wall thickness at and just above ground level. Corrosion had occurred to both internal and external surfaces; internally because water had entered the post and there was no drainage for it to escape, while the external corrosion was affected by the base being buried in ballast, which held water around the base and damaged the protective coating on the signal post.
Signal posts are subject to annual visual examinations, but the examinations of this signal did not detect the problem because the main area of corrosion was hidden by ballast, and the examinations regime was vulnerable to missing such defects. A separate examination in 2012 for a resignalling project in the area also did not detect the defect for similar reasons. Because the defect was not detected, it was not subsequently reported and remedied through maintenance.
The investigation also identified possible underlying factors associated with the management of ballast levels around post bases, competence management of structures examiners and corporate knowledge about the original design specifications for signal structures.
The RAIB has identified one learning point and made five recommendations. The learning point relates to the process for conducting visual examinations on structures such as signal posts. Four of the recommendations are addressed to Network Rail and cover the management, examination and resilience of signal structures to such failures. The remaining recommendation is addressed to Amey regarding its competence management arrangements for structures examiners.
