No recent travel & transport from BBC stories as at 23:35 26 Apr 2025
Train RunningDelayed
20:03 London Paddington to Plymouth
20:20 Hereford to London Paddington
20:23 Portsmouth Harbour to Cardiff Central
20:30 London Paddington to Exeter St Davids
April 26, 2025, 23:36:26 *
Author Topic: Any permitted route question  (Read 7224 times)
tom m
« on: September 07, 2014, 22:22:13 »
Hi All,
I know not strictly FGW (First Great Western) related but I am hoping someone can help me out. I am looking to make a journey between Datchet and Gatwick Airport on an open return (don't know exact date I will be coming back yet). I would like to route via Weybridge but I am struggling figure out if this is allowed under the "Any permitted" or "not via London" options I have found. I have tried looking at the National Routeing Guide but I really cant make head nor tail of it, could someone with a bit more experience tell me if I can do this please?
Interestingly I noticed in my search the fully flexible ticket with the return valid for a month is only available on certain  journeys, I had always assumed that the an open return was available to anywhere?
« Reply #1 on: September 07, 2014, 23:25:00 »
First off, there are many flows where there is no Anytime Return, particularly in the former Network SouthEast area. Such journeys, out one day and back another, both at peak times, have to be done with 2x Anytime Day Singles. There are also some flows in other parts of the country where the Off Peak Return has no time restrictions, meaning there is no need for an Anytime Return.
Now as to the routeing question.
Datchet is not a Routeing Point in it's own right, but is associated with Slough and Staines.
First thing to check is the shortest route between origin and destination as this is always valid. That is:
Datchet, Sunnymeads, Wraysbury, Staines, Ashford (Surrey), Feltham, Feltham Junction, Whitton Junction, Whitton, Twickenham, St Margarets (Greater London), Richmond, North Sheen, Mortlake, Barnes, Putney, Wandsworth Town, Clapham Junction, Wandsworth Common, Balham, Streatham Common, Norbury, Thornton Heath, Selhurst, East Croydon, South Croydon, Purley Oaks, Purley, Earlswood (Surrey), Salfords, Horley, Gatwick Airport
So essentially, Datchet to Clapham Junction, change, then Clapham Junction to Gatwick Airport.
Next you need to do a fare's check on the associated Routeing Points. If the fare from the Routeing Point is more expensive than the fare from the origin station then it is not permitted to use that Routeing Point. That isn't straightforward as it depends on the ticket type being purchased. Some fares between Datchet - Gatwick are cheaper than Slough - Datchet meaning Slough wouldn't be an appropriate Routeing Point, but others would pass the fare's check rule, allowing Slough as an appropriate Routeing Point. We'll leave that thorny issue to one side though as you want to travel via Weybridge which logically means using the Staines Routeing Point.
So, is Staines Routeing Point to Gatwick Airport (which is also a Routeing Point) via Weybridge a permitted route?
First we look at the Routeing Guide's Permitted Route Identifier. From that we see that Staines-Gatwick Airport has two Permitted Routes. The first is LONDON and the other is to be traced on Routeing Guide maps WX+LB.
LONDON means you take any permitted route between origin Routeing Point and London, then any permitted route from London to destination Routeing Point. We can discount that for your query as there are no routes from Staines to LONDON via Weybridge. The only permitted route is that which can be traced on Map WX.
So, that leaves us with the map combination WX+LB. As Map WX is the same one as used for Staines-LONDON then sadly that also rules out travelling via Weybridge.
In summary. Datchet to Gatwick Airport via Weybridge is not a permitted route.
If you wish to travel via Weybridge then you will need two tickets.
« Reply #2 on: September 08, 2014, 20:55:57 »
Mutter ... Mornington Crescent ... mumble  Roll Eyes
« Reply #3 on: September 08, 2014, 21:29:43 »
Sorry, but Mornington Crescent is not on a permitted route either.  Unless you are using the 'North London rules' where contraflows are inverted to avoid triangulation, and Dollis Hill is wild. Tongue
tom m
« Reply #4 on: September 08, 2014, 22:33:20 »
Thanks bignosemac, looks like I will have to buy two separate tickets which look like the are going to be more expensive if I want fully flex  Sad
SDS
Badgerline
« Reply #5 on: September 09, 2014, 00:11:47 »
Finchley Central. I win!
I do not work for FGW (First Great Western) and posts should not be assumed and do not imply they are statements, unless explicitly stated that they are, from any TOC (Train Operating Company) including First Great Western.
