No recent travel & transport from BBC stories as at 11:35 11 Jan 2025
 14/01/25 - Rail Sale starts
11th Jan (2012)
11:19 Frome to Weymouth
11:50 London Paddington to Hereford
14:00 Bristol Temple Meads to London Paddington
08:48 London Paddington to Carmarthen
11:09 Gloucester to Bristol Temple Meads
January 11, 2025, 11:46:55 *
[91] Thames Valley infrastructure problems causing disruption elsew...
[80] Westminster Hall debate : Railway services to South West
[56] North Cotswold line delays and cancellations - 2025
[49] one pound flat rate bus fares in Devon and Torbay area.
[49] Ryanair sues 'unruly' passenger over flight diversion
[44] Mick Lynch announces retirement as head of RMT
Author Topic: Do i Have to Change at Didcot?  (Read 3478 times)
« on: October 14, 2013, 14:56:31 »
Coming back from Cardiff on the 18:30 Saturday 19th (advanced ticket) so seat reservation. I know it will be the old SWML (South Western Mail Line) so quite slow but the reservation is only to Didcot where iI should change for Taplow. Do I have to change at Didcot? Can I go to Reading where there is an off chance of getting the  previous train to Taplow (2 minutes!!). Even if I miss it, it means I would catch the same train as from Didcot plus the  chance of getting a pint in the Three Guineas.
« Reply #1 on: October 14, 2013, 19:23:08 »
I assume you have an Advance from Cardiff to Taplow with an itinerary that suggests a change onto a Thames Valley service at Didcot.
I don't see there being too much of an issue in staying aboard the HST (High Speed Train) as far as Reading and changing onto your unreserved local service there. Worth mentioning it to the Train Manager before Didcot just for peace of mind.
As your subsequent train is unreservable you are free to take an earlier/later service if you have to/want to. So you can make the 2 minute connection at Reading or have that pint in The Three Guineas
« Last Edit: October 14, 2013, 20:32:34 by bignosemac » Logged
Southern Stag
« Reply #2 on: October 14, 2013, 20:12:00 »
If you use the FGW (First Great Western) booking engine to book your tickets, or any other 'mixing deck' based booking engine if you specify a journey avoiding one of the local stops between Didcot and Reading, such as Cholsey it will force a change at Reading. That won't work on Trainline based booking engines though.
« Reply #3 on: October 15, 2013, 00:07:50 »
Is there not a 'via' option on trainline based booking engines?
« Reply #4 on: October 15, 2013, 08:10:49 »
Booked through Chiltern as being the least worse TOC (Train Operating Company). Didn't see the seat reservtion was only to Didcot.
Southern Stag
« Reply #5 on: October 15, 2013, 09:09:03 »
Yes, but trainline based booking engines take account of passing points whilst mixing deck ones don't. Specifying not via Cholsey on trainline booking engines will literally force you on a route avoiding Cholsey whereas mixing deck booking engines will just force you on a train which doesn't stop at Cholsey.
