Travel & transport from BBC stories as at 08:35 29 Apr 2025
29th Apr (1963)
Bristol Bus Boycott announced (*)
06:38 Weymouth to Gloucester
08:06 Bristol Temple Meads to Gloucester
08:23 London Paddington to Oxford
08:25 Reading to Gatwick Airport
08:45 Truro to Falmouth Docks
08:54 Reading to Gatwick Airport
09:15 Falmouth Docks to Truro
09:30 Gatwick Airport to Reading
09:59 Gatwick Airport to Reading
10:59 Gatwick Airport to Reading
05:23 London Paddington to Swansea
05:55 Bristol Temple Meads to Penzance
05:57 Swansea to London Paddington
06:47 Bristol Temple Meads to Penzance
06:52 Weston-Super-Mare to London Paddington
06:54 Taunton to London Paddington
07:00 Gloucester to Plymouth
07:24 Taunton to London Paddington
07:52 Reading to Gatwick Airport
08:11 Gloucester to Frome
09:09 Gloucester to Weymouth
09:18 London Paddington to Cardiff Central
09:32 London Paddington to Cheltenham Spa
10:30 London Paddington to Weston-Super-Mare
04:54 Plymouth to London Paddington
07:34 Redhill to Reading
08:15 Falmouth Docks to Truro
08:45 Falmouth Docks to Truro
09:38 Bristol Temple Meads to Worcester Foregate Street
April 29, 2025, 08:54:00 *
[361] Chiltern Railways: an update on rolling stock / services
[56] Doublebagging, Rawdoggers, Barebackers
[49] Driving licences and tests - ongoing discussion, merged topics
[36] Station Jim’s whereabouts
[34] Thames Valley infrastructure problems causing disruption elsew...
[30] North Cotswold line - driver route knowledge
Author Topic: Today 27/12/2007  (Read 10809 times)
johoare
« on: December 27, 2007, 16:34:21 »
Well.. Having worked most of the night, and being allowed a couple of hours sleep.. I decided to get the (later than I planned) 11.37 Maidenhead to Paddington to work.. It was one of the few (hourly) fastish trains timetabled...
But it was cancelled.. I ended up on the 11.12 which was running very late, stopped everywhere and was, as expected in the circumstances, crammed full of people..
And all I wanted to do was get to work! I felt quite ill by the time I got to Paddington...
Oh, and despite the fact it was a quietish train day, we got dumped on platform 14 anyway.. why do they keep doing this? Those platforms should be for emergencies only... There were other empty platforms today. I didn't want a 5 minute walk with hundreds of other people just to get to Paddington when I was already late..
Thank you to the train driver for all his annoucements though.. and keeping us well informed..
« Reply #1 on: December 27, 2007, 16:44:05 »
Bear in mind there was a broken down train which threw the whole of Reading - Paddington into chaos (again)
I'm sure there was also a perfectly good reason why that platform was used   Smiley
BBM
« Reply #2 on: December 27, 2007, 19:21:24 »
Well if there is a good reason I'd like to hear it! I've lost count of the number of times over the past few years when I've been dumped in 13 or 14 at off-peak times whilst 9, 10, 11 & 12 were all completely empty. It happens time and time again!  Angry
Ollie
Moderator
« Reply #3 on: December 27, 2007, 19:26:19 »
Platforms 13 and 14 are only used by Turbo operated services.
Platform 12 is primarily for the Heathrow Connect except in peak when is sometimes used by Turbo operated services.
Platforms 1-5 and 8-11 can be used by Turbo and HST (High Speed Train (Inter City class 43 125 units))/Adelante
During times of disruption it is better to put a turbo on 13/14 so a HST can possibly use some of the other platforms.
Also the fact Platform 14 could have been the booked platform anyway, e.g. the train you came in on could have been going back out to Greenford?
« Reply #4 on: December 27, 2007, 19:39:33 »
The driver has no control, I don't think Slough IECC (Integrated Electronic Control Centre) are overly bothered that some punters have to walk further either.
johoare
« Reply #5 on: December 27, 2007, 23:29:34 »
So even though FGW (First Great Western) tell us that local services are not less important than HST's... they are?
I could just about understand it if it was a busy rush hour, but it wasn't! Half the platforms were empty, and I am sure they stayed that way...  I am fed up with having an extra 5 minutes added to my (usually) delayed train by having to walk the rest of the way. I know of no other London mainline stations where two platforms are further away from the main station than leicester square tube is to covent garden tube.. As someone else on here said a while back, it's like another station. And should be treated as such!
johoare
« Reply #6 on: December 27, 2007, 23:31:08 »
Maybe the people in charge of putting trains on platform 13/14 (when there is no apparent good reason) should be made to do this journey every day then!
« Reply #7 on: December 28, 2007, 10:44:30 »
Its not FGW saying that.
Railways work by classing trains and by using headcodes.
A headcode is basically the identity of the train seen at the signal box and through various other railway systems.
A headcode is a 4 digit/letter code, 1A05 for example, in this case the 0640 Bristol - Paddington.
The first number is how important the train is. 1 stands for an express passenger train such as an HST. 2 would be a local surburban service such as the stopping turbo you are on. As a result your train is less important to the signal box and a class '1' train would get priority over a junction/platform.
The second letter in the headcode is the destination, 'A' referring to London, and the last two letters are the individual identity.
Hope that clears up why local commuter trains are often not given the same priority as high speed trains, regardless of FGWs view on it. At the end of the day Slough IECC (Integrated Electronic Control Centre) (the signal box) make the decision as to which train goes in front of you, which platform etc etc
« Reply #8 on: December 28, 2007, 11:08:50 »
More on yesterday's events (link below.)
http://www.maidenhead-advertiser.co.uk/news_article.php?section=5&category=89&story=5208
« Reply #9 on: December 28, 2007, 11:17:52 »
Didn't think to mention that it WASN'T a FGW (First Great Western) train that broke down did they?
vacman
« Reply #10 on: December 28, 2007, 12:27:49 »
A class 2 train is a "normal" passenger train whilst a class 1 is an "express" passenger or mail train, don't mean to be a smart arse but i'm bored.  Cheesy
TerminalJunkie
« Reply #11 on: December 28, 2007, 12:37:42 »
Quote from: vacman
Do you mind? That's my excuse!
Daily Mail and Daily Express readers please click here.
vacman
« Reply #12 on: December 28, 2007, 12:39:10 »
Well it is Christmas  Grin
johoare
« Reply #13 on: December 28, 2007, 18:20:09 »
Well unless FGW were misquoted, they hadn't mentioned it wasn't one of their trains either.. I guess the Maidenhead advertiser were just reporting what they'd been told?
I quote from the article...
"A spokesman for the company said: "There were problems this morning with broken down services at Hayes and Harlington."
Usual lack of information then!
Mookiemoo
« Reply #14 on: December 28, 2007, 20:15:50 »
All FGW had to do was say....
"A spokesman for the company said: "There were problems this morning with broken down XYZ services at Hayes and Harlington."
Ditched former sig - now I need to think of something amusing - brain hurts -I'll steal from the master himself - Einstein:
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe."
"Gravitation is not responsible for people falling in love"
