No recent travel & transport from BBC stories as at 16:15 10 Jan 2025
 14/01/25 - Rail Sale starts
10th Jan (1863)
14:54 Cardiff Central to London Paddington
15:00 Bristol Temple Meads to London Paddington
16:32 Great Malvern to London Paddington
16:59 Cheltenham Spa to London Paddington
14:53 London Paddington to Worcester Foregate Street
15:14 Exeter Central to Barnstaple
16:49 Reading to Gatwick Airport
13:15 Plymouth to London Paddington
13:55 Paignton to London Paddington
15:30 Bristol Temple Meads to London Paddington
15:59 Cheltenham Spa to London Paddington
16:31 Barnstaple to Exeter St Davids
17:15 Exeter Central to Barnstaple
January 10, 2025, 16:33:05 *
[105] Westminster Hall debate : Railway services to South West
[103] Ryanair sues 'unruly' passenger over flight diversion
[92] Mick Lynch announces retirement as head of RMT
[49] Thames Valley infrastructure problems causing disruption elsew...
[44] Birthday trip, Melksham to Penzance - 28th January 2025
[23] A Beginner's Guide to the Great Western "Coffee Shop" Passenge...
Author Topic: SWT ordering new rolling stock  (Read 10794 times)
anthony215
« on: August 08, 2013, 14:40:33 »
This has appeared on other forums so thought I would post it in case anyone hasnt read it yet.
http://www.railwaygazette.com/news/single-view/view/south-west-trains-plans-suburban-train-order.html
Edited by Brucey to fix a broken link
« Last Edit: August 08, 2013, 15:07:08 by Brucey » Logged
johoare
« Reply #1 on: August 08, 2013, 14:46:58 »
Thanks anthony215. That link didn't work for me though
Brucey
« Reply #2 on: August 08, 2013, 15:08:26 »
I've edited the link in anthony215's original post.  Appears it got truncated at some point.
Are we aware yet whether these are to replace the 455 units or for use in addition?
« Reply #3 on: August 08, 2013, 15:49:27 »
All additional, going by various magazine articles, and what has been announced already by SWT (South West Trains).
In the case of the 455s, they aren't going anywhere.  They've only just announced they are to be given new AC traction equipment, that will only be cost effective if the 90 odd units are being kept for the medium term.   The numbers in the new order are about what you need to increase all the remaining inner suburban 8 car services to ten car, the Reading line from 8 to 10 car, and all remaining long distance services from 8 to 12 car.
Although the 456s (48 vehicles) were widely reported as directly augmenting the 455 fleet, as can be seen from SWT's 2012 press release they only provide a minimal increase in capacity in the main line side inner suburban area, they are in fact also being deployed so as to allow cascades of 450/458 to increase the length of long distance EMU (Electric Multiple Unit) services from places like Alton, Haslemere, Portsmouth and Southampton, and strengthen DMU (Diesel Multiple Unit) services via Salisbury.  Apparently it turns out the likeliest place to see 456s when they first come into use with SWT will be on Guildford to Ascot shuttles, releasing a few 450s and 458s for use elsewhere...
Network SouthEast
« Reply #4 on: August 08, 2013, 21:21:21 »
The retractioning of the class 455 fleet will allow units to go longer between routine maintenance. It is this retractioning project, which will free up just enough capacity at Wimbledon Park to accommodate the maintenance of these new trains without a new depot needing to be built.
« Reply #5 on: August 08, 2013, 22:31:53 »
Wonder if Siemens will find the spare manufacturing capacity to bid  Grin
inspector_blakey
« Reply #6 on: August 09, 2013, 20:29:31 »
Although the 456s (48 vehicles) were widely reported as directly augmenting the 455 fleet, as can be seen from SWT (South West Trains)'s 2012 press release they only provide a minimal increase in capacity in the main line side inner suburban area...
As I understand things, the current intention is for them to be used, together with the refurbished 458/5 units, to deliver the "ten-car railway" plans on the Windsor lines for which may platforms have recently been extended. Do bear in mind that although strengthening of trains to ten cars on the main suburban side is planned, it will take somewhat longer because it will require significant remodelling work at Waterloo, where platforms 1 - 4 can only handle 8 x 455 each.
« Reply #7 on: August 09, 2013, 20:49:57 »
Discussions elsewhere a few months ago suggested that very few if any of the 456s will operate on the Windsor side.  8 or 9 will apparently be used on Guildford - Ascot shuttles, and most of the rest will work on the main suburban side (ie through Wimbledon), but not generally in 4+4+2 formations with 455s, as was expected.  SWT (South West Trains) insiders reckon a number will work paired up as half of an 8 car (4+2+2) formation, and that this then releases 455s to run additional peak trains, for example they plan to have a couple of extra services running in to Waterloo from Raynes Park.
The other point of course is that there's a continuing 455 overhaul programme for DDA» (Disability Discrimination Act - about) mods, and a separate programme for retractioning, that also affect the number of units that are available for a two or three year period.
What I mean is that the 24 units (say 20 or 21 diagrammed daily) won't generally augment pairs of 455s up to 10 car, which was the popular assumption. SWT's announcement that the 456s were arriving listed only the following changes that can be considered 'suburban', most of the enhancements listed were to mainline longer distance services, presumably via cascaded 458s or 450s:
Suburban services:
0717 from Guildford via Cobham (8 car to 10 car)
0807 from Guildford via Cobham (8 car to 10 car)
0817 from Woking (8 car to 10 car)
1702 Guildford via Woking (8 car to 12 car)
1732 Guildford via Woking 8 car to 12 car)
1757 Twickenham via Kingston (8 car to 10 car)
1848 Guildford via Cobham (8 car to 10 car)
Windsor lines:
1705 Aldershot via Richmond (4 car to 8 car)
1713 Teddington via Richmond (8 car to 10 car)
Additional services:
0722 from Raynes Park
0922 from Raynes Park
AIUI (as I understand it) the 10 car Windsor side, (Windsor and Hounslow loop etc), is well within the capacity of the full 458/5 fleet, basically they are using 36 merged units to operate the routes that were previously covered by the 29 HC 450/5 conversions.  Another relevant issue is that the 455/456 fleet cannot be used on the Windsor side 10 car routes where SDO (Selective Door Opening) is  going to be used (ie minor stations beyond Staines towards Windsor) so their normal operating area has to be on routes where all platforms are extended - and that poses the difficulty that you have pointed out already that they cannot run into Waterloo P1-4.  It seems the limited number of main suburban 10 car trains will use P5 and P6.
« Last Edit: August 09, 2013, 20:59:47 by paul7755 » Logged
