Travel & transport from BBC stories as at 01:35 19 Apr 2025
19/04/25 06:52 Par to Newquay
03:34 London Paddington to Reading
April 19, 2025, 01:40:47 *
Author Topic: Thames Valley branches post Crossrail and electrification  (Read 17763 times)
Btline
« on: July 23, 2012, 10:14:55 »
Before the electrification plans, it was assumed that no through trains would run to London.
What do people think will happen now? Part of Crossrail - i.e. slow? Fast "Greater Western Franchise" trains to Pad in peaks?
« Reply #1 on: July 23, 2012, 10:32:53 »
Assumed by who?  The Greater Western franchise consultation asked the following question:
Under current plans for electrification, any direct services from the Henley and Bourne End branches to Paddington would still have to be diesel- operated. Respondents are encouraged to consider if these services would represent a good use of scarce timetable slots on the main line, given that these slots could be used by higher-capacity electric trains.
They won't be part of Crossrail if Crossrail continues with its current preference of 10-car EMUs (Electric Multiple Unit) as there's no way platform extension work would take place even if SDO (Selective Door Opening) was used.  My bet would be on a reduction to one direct train from Henley and Bourne End to Paddington in the morning running as a 4 or 5-car EMU and running fast from Twyford (Henley) and Maidenhead (Bourne End), and a similar service returning in the evening.  Or, perhaps two through trains could still run, but with them coupling/uncoupling at Maidenhead and running as two 4 Car units between Maidenhead and Paddington?
There will be a lot of lobbying nearer the time I should imagine!
« Reply #2 on: July 23, 2012, 21:28:37 »
As I posted under the Western Airport link I think it's time somebody sat down and worked out how Crossrail, Hex, Connect, FGW (First Great Western)  stoppers, semis and ICs (Inter City) plus frieght are going to work with the Western Junction open and the Marlow and Henley branches and  Bristol, Swansea plus Newbury and Oxford electrified.
What I want is a decent integrated service serving all stations between Newbury and Oxford to Heathrow, Padd and Crossrail. With semis serving pricncipel stations. I don't give a damm who runs it, plus it's all public money so it doesn't matter whose bucket it comes from.
So another of my rocks. How about making Iver a turnback for some ex Crossrail stoppers? If somebody could find a bucket somewhere, maybe the money from not building the the Maidenhead turnback. By utilising the goods loop from west Drayton and putting a platform by it and maybe reinstating the old runround you've got a turnbabk siding, with suitable crossings you can have the Up Relief bi-directioanlly signalled so termniating trains can be overtaken. Basically it seems to me better than West Drayton.
Hayes would also be a good place to terminate stoppers a right crossover Down Relief Up Relif near the canal bridge and link the bay platform with the goods loop (already electrified) over the canal bridge. Again Up Relief can be bi-diectional from Southall West to Hayes.
At the moment everyone is so taken with Crossrail that they don't realise that by terminating at Maidenhead it completely disrupts the current passenger flows between Reading (and West thereof) to Maidenhead Slough Hayes and Ealing which are quite heavy and serverely limits rush hour fast to Padd from Maidenhead and Twyford to Padd..
« Reply #3 on: July 24, 2012, 08:43:06 »
The western terminal at Maidenhead for Crossrail along with the turnback facilities have been left in place as it is in the Crossrail Act it also is a clean project line between the GW» (Great Western - used as an abbreviation for the area / lines under the Great Western franchise, as opposed to FGW which includes "First", the company operating them too. For tickets - about) electrification and Crossrail funding, design and construction contracts.
Because of the way the funding for these schemes is done (a political decsion to do it this way) Crossrail is funded by TfL» (Transport for London - about) GW electrification by DfT» (Department for Transport - about) the additional power supply and electrification GW requires in the Crossrail patch has been complex enough to get agreement, to merge the 2 would have need a change to the Crossrail Act which would just added delay and cost.  I suspect that Maidenhead will always retain a Crossrail turnback even if Crossrail is extended to Reading for emergency use.  Reading only has pasive Crossrail provision.
« Reply #4 on: July 24, 2012, 10:24:51 »
As far as I'm aware, and if the plans haven't changed, the goods loop between Iver and West Drayton does become the Up Relief Line and is extended back from just east of Langley station.  Iver will then have a Platform 5.  The current Up Relief becomes a bi-directional passenger line, which will presumably be used to recess freight services as well as allowing semi-fasts to overtake stopping Crossrail services with a predominantly Up direction flow in the morning peak and Down direction in the evening peak.
autotank
« Reply #5 on: July 24, 2012, 10:38:46 »
I believe the only thing preventing 8 car through trains to London on the Henley line would be the length of Wargrave platform? Wouldn't an 8 car 319 be about the same length as a 7 car 165/6? I've seen 7 cars on the branch during Regatta so it should be possible - would certainly be nice to see!
« Reply #6 on: July 24, 2012, 15:18:40 »
Nominally 160m vs 161m, but the exact lengths would be needed.  I'd expect it would be well within the length of the existing platform end ramps though, so all that should be needed is to square them off to horizontal, which is OK under current design standards.
« Reply #7 on: July 24, 2012, 18:10:31 »
Exactly my point when Crossrail was proposed there was no sign of GWML (Great Western Main Line) being electrified. Not only are we getting wires to Reading and beyond  but Newbury and Oxford plus Windsor Marlow and Henley and now there is possibily of the Western junction for LHR.
To my mind having Crossrail terminating at Maidenhead is pointless and completely upsets the current traffic flow from the West of Maidenhead to intermediate stations between  Taplow and Acton.
It seems to me the that someone needs to work out how the TV (Thames Valley) suburban servce will be run as a complete service irrespective of who runs it.
Acts can be changed, it would take a couple of hours in parliament, then it will take 10 secs to transfer the money from one budget to the other.
« Reply #8 on: September 04, 2012, 21:34:40 »
What stock is going to be used on the Marlow branch come electrification?
The down platform at Bourne End, which is the only one that allows access to and from Marlow, is only long enough for a two car train.
319s are likely to be cascaded to the Thames Valley, but these four car units would be too long to serve Bourne End-Marlow.
Is it likely that the wires will end at Bourne End and a diesel shuttle will be locked into the branch to Marlow? Or will the wires go up in hope of a future 2 car EMU (Electric Multiple Unit) build for other parts of the country from which a small sub-fleet can be used in the Thames Valley? There are currently no 2 car pantograph EMUs in existence in the UK (United Kingdom).
There appears no way that the down platform at Bourne End can be lengthened in either direction.
« Reply #9 on: September 04, 2012, 22:19:03 »
I think it was 'Electric Train' that suggested in another thread that if the stop blocks were moved at Bourne End to a position level with those on the other platform (i.e. flush to the platform end), along with a reposition of the point indicator signal, then there would just be room for a 3-car 20 metre long EMU (Electric Multiple Unit), which, together with a short extension of the platform at Marlow, would mean that could operate the service through from Maidenhead to Marlow.
This picture demonstrates the Bourne End situation perfectly: http://www.panoramio.com/photo/48405051?source=wapi&referrer=kh.google.com
I'm currently working on a 'mega-post' trying to sum up all the issues that will arise with the LTV (London [and] Thames Valley) services by the end of the decade (and my guesses as to the best/likely solutions), as by then Crossrail, and electrification will impact on virtually all the routes.
« Reply #10 on: September 05, 2012, 10:00:48 »
That would be very good to see your thoughts on LTV (London [and] Thames Valley) services  Industry Insider.
I just hope that they don't build the turnback sidngs at Maidenhead it would seem a complete waste of money and totally disrupt the establisehed pattern of services.
I and other like grahame have posted on a number of occasions that the pattern of train services is very important socialogically as many people choose ther homes and jobs to fit in with the train service.
Thus there are large number of people from Twford and Westwards who travel to Slough  and principle stations to Ealing. Similarly there is smaller counterflow from East of Maidenhead to Reading and maybe beyond like Oxford. So to have to change at Maidehead would be amajor disruption and add to theiri travel time.
Ross H
Jr. Member
« Reply #11 on: September 05, 2012, 12:37:03 »
There are currently no 2 car pantograph EMUs (Electric Multiple Unit) in existence in the UK (United Kingdom).
Indeed. If three cars could be accommodated, they could take the non-driving trailer out of a 319 (or 317, of which I think there are some spare already), to make a 3 car EMU. If only two cars will fit, I suppose they could modify a 317 to a 2 car EMU by converting one end of the non-driving power car to a cab, in the same way that the 153s were created out of 155s.
« Reply #12 on: September 05, 2012, 12:50:26 »
Or some surplus 3-Car Class 313s from FCC (First Capital Connect)?  Not a long term solution given their age mind you!
anthony215
« Reply #13 on: September 05, 2012, 18:42:46 »
Might be a solutiuon if Southern decide to give up their class 313's
« Reply #14 on: September 05, 2012, 19:55:35 »
Things to ponder
165/6 vehicle length 74 ft
319 vehicle length 65 ft
319's are 4 car units so will not fit at Bourne End Plat 1, 3 car 313's would be a tight fit.  A 2 car diesel shuttle Bourne End / Marlow outside the peak would not be viable and would lead to the closure of this section of the line.  The other option is to loose plat 1 at Bourne End and run the whole branch as one block this would stuff the am and pm half hourly shuttle but would allow 4 car units to Marlow
So far the points have been based on existing stock and formations, the TV (Thames Valley) branches (Windsor, Marlow, Henley and Basingstoke) are viable out of the peaks with 2 car units so it is likely that 313 Units could get reconfigured to produce 2 car units with the spare cars being cascaded .................. or may be we will get new Units!!!!!
In reality I doubt anyone in the ORR» (Office of Rail and Road, formerly Office of Rail Regulation - about) or NR» (Network Rail - home page) have done any in depth study into this
