« Reply #1 on: February 26, 2012, 19:29:41 » |
..... and Sarah Siddons. The steam locos used by the GWR▸ were condensing engines based at OOC▸ . All that needs to be done is to put the links back it at Padd from the hot n cold to the reliefs, at Faringdon to Snow Hill tunnel and Liverpool St to Spitlefields and then there would be little need for Crossrail Nowt like going full circle
« Reply #2 on: February 26, 2012, 21:04:03 » |
But they didn't condense all the time  The equipment made the locos very difficult to drive and so drivers regularily didn't condense.
onthecushions
« Reply #3 on: February 27, 2012, 23:02:51 » |
..... and Sarah Siddons. The steam locos used by the GWR▸ were condensing engines based at OOC▸ . All that needs to be done is to put the links back it at Padd from the hot n cold to the reliefs, at Faringdon to Snow Hill tunnel and Liverpool St to Spitlefields and then there would be little need for Crossrail Nowt like going full circle  What a splendid idea. Even the platform ends at Paddington still have the curves for the connection. I've often wondered why LUL▸ prefers to send half empty A stock into wildest Bucks and Herts rather than carry serious passenger flows out West (including Heathrow). Weren't the Mersey Railway locos condensing, also? OTC
Gordon the Blue Engine
« Reply #4 on: February 28, 2012, 17:46:19 » |
When I was a fireman (on 2ft 6in, not 4ft 8 1/2in) it was considered very bad form to be wasting steam from the safety valve. Coal is expensive.
« Reply #5 on: February 28, 2012, 23:17:43 » |
OTC
Have you tried using the Met/Circle line in the peak. Of course you could get through trains onto the line - but you would have to get rid of the Circle/Hammermith & City and Metropolitan Line trains first.
inspector_blakey
« Reply #6 on: February 29, 2012, 00:20:14 » |
I have read elsewhere that the loco was deliberately left to blow off heavily as the video was principally of a test to establish if a steam loco with the safety valves lifted for an extended period of time was going to send the fire detections systems in the station haywire. Another reason why the test was conducted in the wee small hours.
« Reply #7 on: February 29, 2012, 08:35:25 » |
Interesting point. And maybe - and I'm not being sarcastic - the blowing piston rod glands were to test for any issue with the third rail. There's ceratinly a lot of steam everywhere.
inspector_blakey
« Reply #8 on: February 29, 2012, 15:11:07 » |
...or it could just be because the loco's a knackered old sack of spanners
tramway
« Reply #9 on: February 29, 2012, 16:12:39 » |
Exactly the same at 2' 3". Fine art to take loco from lighting up to first off without lifting the valves. Nearly 3 hours of TLC▸ to get there. Happy days.
« Reply #10 on: February 29, 2012, 20:59:15 » |
..... and Sarah Siddons. The steam locos used by the GWR▸ were condensing engines based at OOC▸ . All that needs to be done is to put the links back it at Padd from the hot n cold to the reliefs, at Faringdon to Snow Hill tunnel and Liverpool St to Spitlefields and then there would be little need for Crossrail Nowt like going full circle  What a splendid idea. Even the platform ends at Paddington still have the curves for the connection. I've often wondered why LUL▸ prefers to send half empty A stock into wildest Bucks and Herts rather than carry serious passenger flows out West (including Heathrow). Weren't the Mersey Railway locos condensing, also? OTC The GWR electrification scheme of the 1920's would have seen through trains from Maidenhead and High Wycombe to the City, some drawings I have seen shows the Maidenhead - Wycombe line doubled ............. to optimism of that eara
onthecushions
« Reply #11 on: March 02, 2012, 18:58:15 » |
Yep. I used to commute via Moorgate. I just noticed how the (seeming) majority of trains were heading North at Baker St and weren't full, wheras the occasional H&C and Circle trains were heaving. I suspect that some could go to Ealing B instead, or even to Greenford or LHR. Lines 5,6 out of Paddington could have dc (transformers permitting) and there's space for 6 tracks to Ealing B except under the North London Line bridge to Acton E junction. The importance of this is that it would give us (F) GW» customers better access to Londres Midi (for Paris etc) and also to the new Euston for HS2▸ Regards, OTC
anthony215
« Reply #12 on: March 02, 2012, 20:39:33 » |
I am certainly looking forward to 2013 with regards to Steam on the MET and on the district line as well.
dviner
« Reply #13 on: March 03, 2012, 13:47:59 » |
I have read elsewhere that the loco was deliberately left to blow off heavily as the video was principally of a test to establish if a steam loco with the safety valves lifted for an extended period of time was going to send the fire detections systems in the station haywire. Another reason why the test was conducted in the wee small hours. My first thought was that it was to give the overheads a good steam cleaning...
« Reply #14 on: March 03, 2012, 14:14:58 » |
The importance of this is that it would give us (F)GW» customers better access to Londres Midi (for Paris etc) and also to the new Euston for HS2▸
Where is Londres Midi? I assume it must be south of the river with a name like that (Le Midi = South). Is it a politically corect name for Waterloo? How does this help with access to Paris and HS2?
