Travel & transport from BBC stories as at 12:35 15 Jan 2025
* Three arrests made over fatal London bus stabbing
15th Jan (2015)
RoSCo Eversholt changes hands (link)
January 15, 2025, 12:53:55 *
[119] England's Best Loved Lost Railway: The Somerset & Dorset Joint...
[81] Return of the BRUTE?
[41] Rail Replacement bus - OK, but I prefer the train.
[41] Ferries across waterways - whether by vehicle, foot or both (m...
[36] The Cheddar Valley Lost Railway - the 'Strawberry Line' from Y...
[36] Eastern Airways to start Southend - Newquay service
Author Topic: Crew Shortage - XC. Limited use of GWR services.  (Read 3260 times)
« on: October 13, 2023, 07:04:42 »
From National Rail
Reduced CrossCountry service on some routes from 11:00 until the end of the day
Route(s) affected
Between Manchester Piccadilly / Birmingham New Street / Bristol Temple Meads and Paignton, between Manchester Piccadilly and Bournemouth and also between Nottingham / Birmingham New Street and Cardiff
Description
A shortage of train crew means fewer CrossCountry services are able to run on some routes from 11:00.
Disruption is expected until the end of the day.
Customer Advice
The following routes are affected:
Trains may be revised to terminate / start back at Bristol Temple Meads.
You can use alternative CrossCountry services that run between Bristol Temple Meads and Newton Abbot. Ticket acceptance is in place with Great Western Railway to use their services between Newton Abbot and Paignton.
Passengers travelling to / from Weston-super-Mare, you can use your ticket on Great Western Railway services between Bristol Temple Meads and Weston-super-Mare.
Trains may be revised to terminate / start back at Reading.
Trains may be cancelled or revised to terminate / start back at Birmingham New Street.
You can use alternative CrossCountry services that run between Birmingham New Street and Bristol Parkway. Ticket acceptance is in place with Great Western Railway to use their services between Bristol Parkway and Cardiff Central.
Check before you travel:
You can check your journey using the National Rail Enquiries real-time Journey Planner
Compensation:
You may be entitled to compensation if you experience a delay in completing your journey today. Please keep your train ticket and make a note of your journey, as both will be required to support any claim.
Noting
... to me that looks limited - a surprise that there is no ticket acceptance in place onto GWR (Great Western Railway) train south of W-s-m and north of Newton Abbot. With everyone under management contracts these days, shouldn't we be joined up enough to say "if your booked train is cancelled you may travel on the nearest before/after trains" no matter who operates them.
... so no cross validity to TfW between Cheltenham Spa and Cardiff either
« Reply #1 on: October 13, 2023, 08:21:18 »
Friday = very busy trains even if all services run normally. Many standing.
Hence no clearance on your suggested routes.
« Reply #2 on: October 13, 2023, 08:53:27 »
"Great Brisish Railways" ... and the need to put the customer first ... ah, one can but dream.
