No recent travel & transport from BBC stories as at 09:55 10 Jan 2025
08:36 Redhill to Reading
10:38 Bristol Temple Meads to Worcester Foregate Street
January 10, 2025, 10:06:15 *
[79] Ryanair sues 'unruly' passenger over flight diversion
[69] Thumpers for Dummies
[56] Westminster Hall debate : Railway services to South West
[52] Railcard Prices going up
[44] Mick Lynch announces retirement as head of RMT
Author Topic: Patchway - station, facilities, events and incidents (merged posts)  (Read 9061 times)
infoman
« on: June 01, 2020, 08:05:14 »
Radio Bristol are reporting,
just wish RB would get the facts correct.
RB state its effecting GWR (Great Western Railway) and cross country and trains maybe diverted
Just wondering if the Portsmouth to Cardiff services can still run or are these services cancelled?
« Reply #1 on: June 01, 2020, 08:15:12 »
Not so sure it’s at Patchway.  Report I heard was that the problem is within the Severn Tunnel itself.
« Reply #2 on: June 01, 2020, 08:19:01 »
From National Rail
Damage to the overhead electric wires between Severn Tunnel Junction and Patchway has resulted in all lines between these stations being blocked.
Trains between Newport and Bristol Parkway / Bristol Temple Meads may be diverted or cancelled until approximately 11:30.
Alternative travel advice:
To help with your journey, tickets will be accepted on the following services:
Transport for Wales between Newport and Gloucester
CrossCountry via any reasonable route
Yes, but as news breaks it's a tradeoff between validating it and letting people know something is happening. Wait for the full facts and people set off from home into the jam when the could really do with being alerted
Severn Tunnel IS used by GWR and Cross Country trains; they are (normally) the two operators.  Agreed that Cross Country in the time frame expected is limited to the single service from Cardiff to 'up north' via Temple Meads which also acts as a commuter train across the Severn.
« Reply #3 on: June 01, 2020, 08:20:05 »
Oh dear .. the section that saw its first electric passenger train yesterday?
« Reply #4 on: June 01, 2020, 09:41:08 »
The 0432 Southampton to Wentloog Freightliner service seems at a stand at Severn Tunnel West, possibly since 0700 since it passed the east portal at 0652, running almost an hour early.
phile
« Reply #5 on: June 01, 2020, 09:47:35 »
Portsmouth to Cardiffs start/terminate Bristol TM(resolve) with passengers advised to travel to/from Cheltenham /Gloucester and then use TFW/XC (Cross Country Trains (franchise)) services.     South Wales to Londons diverted via Gloucester
« Reply #6 on: June 01, 2020, 10:08:58 »
The OTT (Open Train Times website) diagram is showing "BLKD" between Patchway and Pilning - suggesting somewhere in or around the Patchway tunnels. It would be a bit ironic if it's that bit of outdoor ROCS (Rigid Overhead Conductor System) we had a picture of.
« Reply #7 on: June 01, 2020, 11:08:21 »
I think it is actually in the tunnel having just entered the signal section up to Severn Tunnel West.
phile
« Reply #8 on: June 01, 2020, 11:15:07 »
It reported hitting something followed by a loud bang and a flash
rogerw
« Reply #9 on: June 01, 2020, 12:34:13 »
Finally on the move again
« Reply #10 on: June 01, 2020, 12:53:35 »
Believed that the freight train hit an 'expansion joint cover' which has been removed and will be repaired next weekend.  Normal working resumed with tunnel energised at 12:18.
It could well have been quite a minor incident, but because it happened in the tunnel it looked and sounded much worse?  Not sure if Electric Train can elaborate?
« Reply #11 on: June 01, 2020, 13:28:32 »
I hope so. But in the meantime, here's some pictures out of Furrey + Frey's ROCS (Rigid Overhead Conductor System) brochure. The beam has a clip-on plastic cover as shown (unless there's an extra-special Severn Tunnel one), so presumably the expansion joint has a bigger cover of its own. Again, what's pictured is the standard part, and as the conductor wire has been changed to an aluminium alloy one it's possible there were some changes to the expansion joint, but I'm sure it still needs a cover.
infoman
« Reply #12 on: April 06, 2022, 06:09:29 »
in connection with sign language.
Being reported on radio bristol at 06:00am on wednesday morning further details when I get them.
MIGHT be covered on the BBC» (British Broadcasting Corporation - home page) local TV news
