« on: September 30, 2019, 07:58:35 » |
From Facebook - Pewsey Notice BoardThe biggest shocker is that the current 0810 off-peak train has been replaced by an 0817 peak-time train. This means that a return to London around that time increases from £53.60 to £120
« Reply #1 on: September 30, 2019, 08:19:38 » |
That depends on whether GWR▸ move the peak time restrictions to take into account of the new train time.
« Reply #2 on: September 30, 2019, 08:50:12 » |
Indeed. At present the GWR site will sell you... 12th December, returns Pewsey to Paddington leaving Pewsey at 07:22 for £120 08:10 for £53.60 10:18 for £40.40 19th December, returns Pewsey to Paddington leaving Pewsey at 07:19 for £120 08:17 for £120 09:30 for £53.60 11:01 for £40.40 There are some good advance fares around on some days, and of course the lower return fares listed above also restrict the time you can return from London.
« Reply #3 on: September 30, 2019, 10:16:38 » |
That's not the point - quite the opposite. The current restriction code for off-peak returns ( LC▸ ) says they are valid for trains after 7:54 - so OK at 8:10, and a fortiori at 8:17. The question is why the times for that code change in December, because they do. Extracting just the Pewsey lines from the long list of "unpublished restrictions" on BRFares (i.e. the machine-understandable version of the text): Outward Journey Summary: PEAK TRAVEL RESTRICTIONS APPLY MON-FRI
Time Restrictions From Until Restriction(s) below apply on these days only: Mon 30 Sep 2019 Sat 14 Dec 2019 Mo Tu We Th Fr Not valid to depart PEWSEY 0430–0754 on any TOC▸ From Until Restriction(s) below apply on these days only: Sun 15 Dec 2019 Sat 21 Dec 2019 Mo Tu We Th Fr Not valid to depart PEWSEY 0430–0859 on any TOC From Until Restriction(s) below apply on these days only: Sun 22 Dec 2019 Tues 31 Dec 2019 Mo Tu Not valid to depart PEWSEY 0430–0859 on any TOC From Until Restriction(s) below apply on these days only: Thurs 2 Jan 2020 Thurs 9 Apr 2020 Mo Tu We Th Fr Not valid to depart PEWSEY 0430–0859 on any TOC From Until Restriction(s) below apply on these days only: Tues 14 Apr 2020 Sat 2 May 2020 Mo Tu We Th Fr Not valid to depart PEWSEY 0430–0859 on any TOC From Until Restriction(s) below apply on these days only: Thurs 28 May 2020 Tues 25 Aug 2020 Mo Tu We Th Fr Not valid to depart PEWSEY 0430–0754 on any TOC Apologies for not tidying up the messy format, but as you can see the start of off-peak moves forward to 9:00 in December, but moves back to 7:55 next May. Now that train (currently the 8:17, later the 8:10) arrives in London well before the normal threshold time for off-peak travel from bigger stations (with more trains), which is why the restrictions are applied one by one to origin stations. Code FO, applying to a wider range of stations (e.g. Reading and Hungerford) has a similar "concession" - and it does the same thing between 15/12/19 and 27/5/20. For Reading the shift is only from 9:29 to 9:39, but it looks to me as if this "mean" version is a direct implementation of "off-peak is available starting with the first train to arrive at Paddington from here after 10:29". It does look like someone's got a program that does this, and has used it uncritically - unless someone knows of a plan to withdraw these "concessions". Just for six months.
« Last Edit: September 30, 2019, 17:40:50 by stuving »
hoover50
« Reply #4 on: September 30, 2019, 16:48:23 » |
I just found another anomaly post 15/12/19
On the National Rail Enquiries website, if I select an off peak return on the 0930 from Pewsey to Padd @£53.60 it shows that it is not valid on the return departures from Padd at 1638 / 1704 / 1737 / 1807
However, if I select a super off peak return on the 1100 (or later) from Pewsey to Padd @£40.40 it shows that it is valid for ANY departure from Padd to Pewsey.
« Last Edit: September 30, 2019, 16:55:00 by hoover50 »
« Reply #5 on: September 30, 2019, 18:00:27 » |
That's generated in much the same way. The super off-peak restriction code ( XC▸ ) also switches to something much more severe in December, then back again in May. Outward from Pewsey, the banned times of morning are 0230–0854 now and from May and 0430–1029 from December. Hence the 09:30 stops being available on an SSR. For return from Paddington in the evening, the now and future ban applies 1507–1855 and 1858–1900, while for the December-May period there just isn't any - instead there is an arrivals ban for 1502–1900! I can understand that the shorter journey times might suggest to GWR▸ management that they should redo the calculation of other-end times based on the veto times at the Paddington end. However, if that's what was intended then it's not been done correctly. It would not be surprising if it was done incompletely, given the scramble to get the timetable together not too long after T-12. However, it's wronger even than that.
« Last Edit: September 30, 2019, 22:06:36 by stuving »
hoover50
« Reply #6 on: September 30, 2019, 20:30:55 » |
It seems the GWR timetable change in December is descending into a complete farce. Let's hope GWR sorts it out as lost of people in Pewsey are getting very angry about this. Apparently it's going to be discussed on BBC» Wiltshire tomorrow!
« Reply #7 on: October 01, 2019, 09:55:02 » |
The trains allowable on an off-peak ticket from Paddington in the late afternoon / early evening also don't look quite right to many destinations. Mind you it often isn't around even a minor timetable change as it is handled so clunkily.
It may be a much more minor change and inconvenience than referenced earlier, but the first off-peak train to London from Didcot will become the 9:27 rather than the 9:17 (not that long ago it was the 9:01). The arrival of this has been accelerated by two minutes, and the valid period put back by one minute so it will arrive three minutes earlier into London than the off-peak valid time rather than bang on it.
« Reply #8 on: October 01, 2019, 10:58:05 » |
With all the Peak/Off Peak anomalies cropping up due to changes to train times I hope that GWR▸ will allow an 'amnesty' period (preferably into mid January 2020) for passengers.
If they are cocking up the fares database then it wouldn't be fair to ching passengers with Off Peak tickets whose only crime is travelling at a slightly different time than they've become used to only because of timetable changes.
"A clear conscience laughs at a false accusation." "Treat everyone the same until you find out they're an idiot." "Moral indignation is a technique used to endow the idiot with dignity."
« Reply #9 on: October 02, 2019, 10:41:32 » |
Same happening here on the Cotswold Line. Savers (i.e. Off-Peak period returns) have been valid since time immemorial on the 06.42 from Hereford (08.35 from Charlbury), which eventually rumbles into Paddington at 09.47. With the timetable change, it's being reclassified as a peak train, seemingly deliberately.
1st fan
« Reply #10 on: October 02, 2019, 16:04:00 » |
A few years ago after a timetable change the train listed in the fares manual as having a Goldcard easement on the Cotswold line disappeared. It was replaced with a train that ran slightly earlier and I wanted to check if the easement applied to this train also. So I called National Rail Enquiries specifically to the call centre in India and asked. They said they don't have access to the fares manual which was no help and odd given they're supposed to handle enquiries. So I called FGW▸ / GWR▸ and asked them the same question. A very nice bloke there checked the new manual for me. He was surprised to find that they hadn't updated things and the old train was still listed. He told me that looking at it historically there was always an easement on the last train before 10am. So he checked with a supervisor and then gave me his name. He said they were authorising the use of a Goldcard for that train and to refer the train manager to him if challenged.
« Reply #11 on: October 02, 2019, 16:17:37 » |
Though in that example the time of the following train is much closer from December - 09:10 as opposed to 09:41, reaching Paddington at 10:24 rather than 10:57. That's probably a fairer time for off-peak tickets to be valid from, but I can see the 09:10 becoming an even more popular train than it is now if it is a 5-car as the 09:41 is currently and it becomes the first off-peak train.
« Reply #12 on: October 02, 2019, 16:22:45 » |
My understanding is that GWR▸ feel, with a generally hourly service improvement, the Cotswold Line is to lose most of their easements and is to fall into line with their general restrictions. so 1000 for the off-peak cutr of at PAD» , with the 'usual' evening restrictions also
« Reply #13 on: October 02, 2019, 23:15:41 » |
Though in that example the time of the following train is much closer from December - 09:10 as opposed to 09:41, reaching Paddington at 10:24 rather than 10:57. That's probably a fairer time for off-peak tickets to be valid from, but I can see the 09:10 becoming an even more popular train than it is now if it is a 5-car as the 09:41 is currently and it becomes the first off-peak train. For Charlbury, that's borne out by journey planners, and by the restriction code - GN. There's no text to say what the morning peak is - just the unpublished restrictions, which give specific peak departure times of 0430–0819 now but 0430–0844 come December. For return times there is in this case a simple statement: Not valid on trains timed to depart:
• London Paddington after 04:29 and before 09:16 and after 16:40 until 18:31 • Reading after 04:29 and before 08:35 and after 17:10 until 19:00 The unpublished restrictions say just that, within a minute, through to after December. GN includes Hereford as an origin, with morning peak coded as 0430–0641 - just not snaring the 0642. For the new timetable that's 0430–0655, which all fits with what ChrisB said about the whole line. But the JPs won't allow the 0642 on an SVR from Hereford, and that's because that ticket has a different code - GK. And GK (which appears to be designed just for Hereford) has peak departures at 0230–0705 now, ruling out the 0642. Come December 15th, that changes to be less restrictive, but only to 0430–0655 (which doesn't seem to affect any trains). For return times there is in this case a similar simple statement: Travelling via Evesham
London Paddington before 09:16 and after 16:40 until 18:20. Reading before 09:40 and after 17:10 until 18:45. but that's not what the unpublished restrictions say; there it is currently 1641–1846, though after December 15th it is 1641–1831. While some of that makes some sense, a lot of it doesn't.
« Reply #14 on: October 03, 2019, 08:39:56 » |
For many of us who use trains at about that time (e.g. from Swindon) there will be incredulity that anyone boarding a London bound train between 07:00 and 09:00 would ever expect it to be anything other than a peak train.
