Travel & transport from BBC stories as at 07:35 23 May 2025
- Ship footage shared with BBC captures sound of Titan sub imploding
- On the South African road incorrectly identified as a 'burial site' by Trump
* Man in Norway wakes to find huge container ship in garden
 today - Go-op Crowd Funding closes
tomorrow - Steamship Shieldhall / Soton
25/05/25 - SWR Franchise expires
31/05/25 - Walk from Trowbridge
No 'On This Day' events reported for 23rd May
May 23, 2025, 07:40:09 *
[171] "The Inspiration Train"
[151] Where was Finn today, 15th May 2025?
[151] Interrail, summer 2025 - daily diary thread of our travels
[97] A trip on the Molli
[44] Broadgage unwell.
[31] Lessons from the line to Tessin
Author Topic: Railways crossing runways  (Read 4335 times)
« on: April 29, 2019, 15:51:16 »
When I was in Ballykelly the railway line ran across the end of the runway, the control tower could turn the signals to red. Don't know if it was interlocked! Get it wrong and the undercarriage running over the train roof would be a wake up. Believe the set-up was unique in Northern Hemisphere.
Maybe ... not sure what the setup was for the Henbury Loop running across the taxiways from the big hangars at Filton.   I expect our S and T Engineering friends will be able to advise.
jamestheredengine
« Reply #1 on: April 30, 2019, 07:47:41 »
Paignton station staff say a 10 coach IET (Intercity Express Train - replacement for HSTs (manufactured by Hitachi in Kobe, Japan)) is too long. I have seen 800's and 802's at Paignton. There was a 158 there today which is becoming more often.
So run it through to Kingswear! :-)
« Reply #2 on: April 30, 2019, 21:10:13 »
I guess the quick and easy fix is to ensure all trains are paper labelled as well, as they used to have to be, until a less quick and easy electronic fix is found?
« Reply #3 on: April 30, 2019, 21:15:10 »
Agreed.  And another thing not mentioned above is that the Seat Reservations are loaded up to a train via the mobile telephone network.  Well, we all know how good that can(not) be at times Roll Eyes
« Reply #4 on: May 07, 2019, 09:46:05 »
I still have the aerodome diagram for the now sadly closed Filton airfield.
In this, the main internal access road between Airbus site and airfield runs across a bridge over the railway line, at around the western end of the old Filton North platforms, just by the helicopter pad on the lower mid-right. The taxiway crossed the railway line at the point marked "F" to the right of one of the windsocks. I last saw that being used by an A380 before they entered service, during fuel trials, unfortunately on a day that I didn't have a camera with me. The line F was a holding point - aircraft could not pass that without the permission of the tower. You could also not start engines or taxy without their say-so. I would guess that the tower would check with the signalman before letting aircraft start up, and that it would be more common for the very occasional aircraft to wait for the then comparatively frequent trains.
I don't recall there being gates on the level crossing, nor any furniture that may have got in the way of a taxying aircraft. The only picture I have of it is a frame-grab from a video taken by my son as I was taking off from Filton for the last time, back in March 2009. The reflection of a hi-vis jacket is a bit annoying, but the crossing is visible.
Academic now, as the airfield site is fenced off from the remaining factory side.
« Reply #5 on: May 09, 2019, 09:40:36 »
I don't recall there being gates on the level crossing, nor any furniture that may have got in the way of a taxying aircraft...
There were very long, wheeled, barriers. You can see the tracks they ran on in this Google maps image: https://goo.gl/maps/E61HYSEZGCT6BbR38
« Reply #6 on: May 09, 2019, 11:04:38 »
Zooming in on the link you can see the barriers which moved eastwards to open them for an aircraft movement. I do recall on the south west corner there was a small fixed control cabin for operating the barriers which was interlocked with the signal box at Filton North in the days before the Bristol Panel Box but how it operated once Bristol Panel took over I can only assume the crossing barriers were interlocked there.
« Reply #7 on: May 09, 2019, 12:08:24 »
I think both Ballykelly and Filton were part of the programme to strengthen and extend runways at the various dispersal airfields for the V Bomber force. Another example, on one of the main airfields, was the large bend in the A15 (was a straight Roman road) round the extended runway at Scampton, also with traffic lights on the road.
rogerw
« Reply #8 on: May 09, 2019, 12:35:18 »
If the Simsig Bristol simulation is accurate, and they generally are, the crossing was released from the Bristol panel following a call from the crossing
Western Pathfinder
« Reply #9 on: May 09, 2019, 17:17:58 »
Filton Runway was originally extended to accommodate the Ill fated Bristol Brabazon iirc.
« Reply #10 on: May 09, 2019, 17:52:22 »
Time to split off this part of the thread?
« Reply #11 on: May 09, 2019, 18:05:11 »
Split off from a topic on IET (Intercity Express Train - replacement for HSTs (manufactured by Hitachi in Kobe, Japan)) deployment which drifted ... original thread at  http://www.firstgreatwestern.info/coffeeshop/index.php?topic=18792.0
