Travel & transport from BBC stories as at 20:15 02 May 2025
 tomorrow - Walk to Pilning
2nd May (1859)
Royal Albert Bridge opens
17:34 London Paddington to Hereford
19:59 Gatwick Airport to Reading
15:50 Penzance to Gloucester
19:12 London Paddington to Bristol Parkway
19:51 Worcester Foregate Street to Bristol Temple Meads
20:06 Westbury to Cheltenham Spa
20:10 Gloucester to Bristol Temple Meads
20:28 Paignton to Exmouth
18:18 Carmarthen to London Paddington
19:48 London Paddington to Swansea
20:23 Swansea to London Paddington
An additional train service has been planned to operate as shown 21:16 Bristol Parkway to Bristol Temple Meads
An additional train service has been planned to operate as shown 21:52 Gloucester to Worcester Shrub Hill
May 02, 2025, 20:30:12 *
[116] In memory of the Weymouth Harbour Tramway on the anniversary o...
[54] Steam excursion - except there's much more diesel than steam!
[49] Taplow-Hassocks
[49] 2025 - Service update and amendment log, Swindon <-> Westbury...
[36] Bath Spa station - dealing with future capacity issues - ideas...
[34] Low passenger numbers due to train unreliability
Author Topic: GWRF2020-08 Direct (through train) service provision  (Read 2355 times)
« on: November 30, 2017, 08:26:22 »
Consultation Question 8
a) Which direct services such as those described above should be preserved in the next franchise?
Why?
b) Are there any other stations between which you feel direct services should be provided?
Why?
c) At which locations should connections between different services be improved? Why?
Explanatory text
Whilst passengers value being able to make direct journeys, some direct journeys may be provided more for operational reasons than because an identified market exists, e.g. linking of services together across Bristol between Great Malvern, Cardiff, Gloucester, Westbury, Weston-super-Mare, Taunton and Weymouth. In these cases, we are unlikely to perpetuate such cross-city linkages, and allowing the next franchisee flexibility to modify service patterns could be important in supporting future service improvements and efficient operations.
However, we recognise that there may be aspirations for a wider range of direct journey opportunities, particularly to and from London, and could require the franchisee to develop proposals for these for possible implementation in the franchise from 2022.
Where it not feasible to provide direct services, we will expect the franchisee to consider providing suitable connections between their own services where possible, e.g. between main line and branch line services in Devon and Cornwall. Where connections may be between different operators, we propose to build on the approach used in recent franchise competitions to seek greater collaboration with other operators and local stakeholders to identify the connections that matter most to passengers, and to coordinate their timetables where practicable to provide convenient connections.
See http://www.firstgreatwestern.info/coffeeshop/index.php?topic=19037 for the background to this topic
« Reply #1 on: December 28, 2017, 06:19:49 »
A flexibility across the city of Bristol (allowing service to terminate there rather than be through such was Weymouth to Worcester) makes sense. However though journeys within the Bristol travel-to-work area that are cross city do benefit from being available without a change of train at Bristol Temple Meads.   For example, passengers from Yatton, Nailsea, Keynsham and Trowbridge (and other stations on those lines) commute in significant numbers to Filton Abbey Wood.
Should though services at peaks be retained across Bristol at least to Bristol Parkway, and if so is it reasonable to ask that this be done at the expense of timing improvements elsewhere in the area?
In Exeter, both St Davids and Central are key commute destinations, with passengers from all directions headed to both of them.   Doesn't it make sense to join up the services so that trains arriving  into Central from the Exmouth and Yeovil Junction lines carry on to St David's, and carry on further from there via Dawlish and via Crediton?
« Reply #2 on: December 28, 2017, 09:08:14 »
How about continuing some Paddington to the South West services via Bristol?  At least as far as Exeter!
Apart from being a useful service it would retain route knowledge for diversions.
