No recent travel & transport from BBC stories as at 16:35 16 May 2025
 tomorrow - Summer Timetable Starts
18/05/25 - Portishead RNLI 10 anniversary
23/05/25 - Go-op Crowd Funding closes
24/05/25 - Steamship Shieldhall / Soton
16th May (1964)
~ Railway Technical Centre, Derby, opens (*)
15:21 Reading to Gatwick Airport
15:29 Gatwick Airport to Reading
16:25 Looe to Liskeard
16:38 Plymouth to Gunnislake
16:59 Basingstoke to Reading
17:20 Reading to Gatwick Airport
17:33 Gunnislake to Plymouth
18:15 Penzance to Exeter St Davids
18:59 Gatwick Airport to Reading
19:05 Reading to Basingstoke
19:24 Reading to Gatwick Airport
19:37 Basingstoke to Reading
19:54 Reading to Gatwick Airport
20:54 Reading to Gatwick Airport
21:30 Gatwick Airport to Reading
22:30 Gatwick Airport to Reading
14:50 Penzance to Plymouth
15:47 Plymouth to Penzance
15:49 Worcester Foregate Street to Bristol Temple Meads
15:55 Exmouth to Paignton
16:31 Barnstaple to Axminster
12:05 London Paddington to Penzance
14:15 Penzance to London Paddington
14:18 Plymouth to Penzance
15:15 Plymouth to London Paddington
16:49 Reading to Gatwick Airport
17:15 Penzance to Plymouth
17:38 Reading to Basingstoke
18:17 Basingstoke to Reading
May 16, 2025, 16:51:04 *
[135] Great British Railways
[106] May Timetable Change
[102] Interrail, Summer 2025 - my catering thread
[77] Where was Finn today, 15th May 2025?
[32] Major rail disruption after blaze close to tracks between Newp...
[29] Champion Reflections
Pages: [1] 2 3 4
Author Topic: Imperial and/or metric units. Discussion on the use and teaching of  (Read 22065 times)
« on: May 27, 2014, 21:46:35 »
(the use of kph is because that is what the line speeds will be stated in also its my antidote to OD of Farage in the media this weekend  Grin )
No doubt though Electric train, like Mr Farage, you'll continue to enjoy the odd imperial pint.  Tongue Wink Grin
« Reply #1 on: May 27, 2014, 22:02:24 »
I quite like litres, BNM.
« Reply #2 on: May 28, 2014, 18:42:44 »
Farage. Mm. French is it?
« Reply #3 on: May 28, 2014, 18:51:52 »
Bit too heavy to lift is a 1000ml stein. Although it does allow for fewer visits to the bar, but possibly more visits to the Gents.
Btline
« Reply #4 on: July 30, 2014, 18:24:12 »
Why use km/h? There is nothing wrong with mph and indeed most drivers will be used to knowing these speeds, I see no benefit of changing.
I also find it difficult myself to imagine the km speeds on this forum as I have to switch to mph to compare it to me driving.
The only line where dual speeds are sensible is HS1 (High Speed line 1 - St Pancras to Channel Tunnel), so any foreign stock can use it without having to have a mph speedo fitted.
Mph is miles better.
« Reply #5 on: July 30, 2014, 18:42:00 »
Tell that to anyone under 30 & they'll tell you they did metric at school
« Reply #6 on: July 30, 2014, 19:20:20 »
41 years old here. And I did metric at skool.
However, ask me my mass in kilograms, or my height in metres, and I've no idea.
« Reply #7 on: July 30, 2014, 19:36:24 »
10 years older and I started doing imperial and then moved to metric (with decimal currency thrown in) and I don't know my hectare from my kilogram...  Grin
« Reply #8 on: July 30, 2014, 19:48:53 »
May be we should use Rods, Bushels and Fortnights as the base units  Grin
Personally I am ambidextrous when it comes to imperial or metric, quit happy working in thous (1/1000") and I am in 1/10mm, although my ^Sd is a bit rusty now  Tongue
NR» (Network Rail - home page) are changing to metric because all the material is supplied in meters, Tonnes all the designs I deal with are in metric even to the extent that "construction mileage" in meters  Roll Eyes  Grin is marked out on site.  The change has been a slow burn but I feel the time is right to make the move on the railways to metric
Alan Pettitt
« Reply #9 on: July 30, 2014, 19:56:46 »
Quite interesting, I am 60 years old, when I first started school we only learned metric, even our rulers were only marked in centimetres, we were taught not to try converting to imperial all the time as by the time we left school nobody would be using it. It was not until I was about 10 that we started to regularly learn feet and inches in addition. Presumably an educational experiment that quietly went down the pan.
BBM
« Reply #10 on: July 30, 2014, 19:57:28 »
52 years old and I did metric at school. I still think in mph though and I can still convert Pounds and Pence to ^SD at the drop of a hat!
Oh and you'll also find km/h signs on NR» (Network Rail - home page) in the Sunderland area where Tyne & Wear Metro trains run on their tracks. Here's an example:
« Reply #11 on: July 30, 2014, 20:13:20 »
I am 57 and learnt both at school. (Though we were allowed to leave out the questions in rods poles and perches)
I too can work in both sets of units.  When I started work the labourers could not (or pretended they could not) work in metric, so I would end up reading the drawing in mm doing the conversion and telling them what to do in ins.
Tonnes are easy as for all practical purposes 1 Ton = 1 Tonne! That conversion is not too challenging.
As for hectares I worked with someone who said he could never get on with them.  We then asked him to estimate an area from the plan. He could not. We then did so in Hectares. He could not understand how we did it until we pointed out that each one of those 100m grid squares on the site plan was 1 hectare. He was converted in an instant as no one could ever do the same for acres!
I am glad I never had to do engineering calculations in imperial units as there are so many factors to include for conversion of units.  Engineering is so much easier in SI units.
Also we thought 17.5% VAT (Value Added Tax) was a pain to work out in metric money, think how difficult it would have been in ^sd!
However permission to be pedantic.  Meters are instruments we use to measure usage of electricity, gas or water and the like.  The SI unit of length is the metre.  The standard English dictionary of international standardisation is The Oxford English Dictionary not Websters!  The Americans might have more claim to set the spelling if they actually used the metre as a unit of measure.
« Reply #12 on: July 30, 2014, 20:31:42 »
I will color my language accordingly ................ don't to be sent to gaol  Roll Eyes or is it jail by the pedantic police  Grin
« Reply #13 on: July 30, 2014, 20:54:28 »
I'm 6 years older, and did LSD at school.* I was the first generation of physics students at my grammar school* to have the acceleration due to gravity at 9.81m/^ rather than 32 ft /s^. But I later worked in France briefly*, and think metric more than I do imperial*, except when driving, where I think in pints (one max)*. Occasionally, I get weighed in hospitals, and the nurse always looks at my weight in kilos, and says, "I'll translate that into rocks and quids for you (or whatever)", and I say don't bother, I work to kilos, which leaves them open-mouthed*, as not even teenagers do that. But calculating body mass index by dividing your weight in Kg by the square of your height in metres must be so much easier than the 19th century equivalent.
(*I'm not proud of everything I've done, although I enjoyed most of it at the time.)
Alan Pettitt
« Reply #14 on: July 30, 2014, 21:10:44 »
I think we need to go easy here or one of our forum bosses will be splitting this off into a "Forum Members' ages and Units of Measurement" thread  Wink
Pages: [1] 2 3 4
