Travel & transport from BBC stories as at 12:35 09 Jan 2025
* Fresh weather warnings for ice across UK
* Man with crocodile skull in luggage arrested at Delhi airport
 today - Bath Railway Society
9th Jan (2004)
11:30 Cardiff Central to Trowbridge
11:39 Weymouth to Frome
12:30 Cardiff Central to Trowbridge
12:54 Filton Abbey Wood to Bristol Temple Meads
13:20 Frome to Weymouth
10:41 Cardiff Central to London Paddington
10:59 Cheltenham Spa to London Paddington
11:30 London Paddington to Bristol Temple Meads
11:30 Bristol Temple Meads to London Paddington
11:32 London Paddington to Cheltenham Spa
11:52 London Paddington to Hereford
January 09, 2025, 12:42:29 *
[198] 'Railway 200' events and commemorations 2025
[109] Thumpers for Dummies
[88] Outstanding server / web site issues
[51] Oxford station - facilities, improvements, parking, incidents ...
[32] Views sought : how train companies give assistance to disabled...
[32] Rail Replacement bus - OK, but I prefer the train.
Author Topic: Future Fares  (Read 13803 times)
« on: December 27, 2011, 14:15:00 »
The Franchise consultation (Pages 51 & 52) seek to bounce the main issue on fares:
Bidders will be expected to assume that existing fares and ticketing policy remains. However, the Government has announced that it will consult on issues Greater Western Franchise Replacement Consultation relating to its fares and ticketing review early in 2012 and the final procurement may need to take account of any policy changes that emerge
However on a more positive light it does say:
Bidders will be encouraged to consider zonal and other fare simplification measures and to consider opportunities for through ticketing schemes where possible.
It also raises the issue of ITSO travel cards (like Oyster (Smartcard system used by passengers on Transport for London services)):
In particular, and in line with recent franchise replacements, bidders will be asked to incorporate ITSO smart ticketing and other technology to review retailing strategy and offer new products. In implementing these new approaches, the franchisee will be expected to participate actively in establishing a common industry approach to the developments so that any changes to the current retailing and ticketing arrangements retain the spirit of the current Network Benefits, providing a single, national passenger-facing framework.
If ITSO is to be implemented then a simplified zonal fares system seems to be the way forward and this would have to get rid of the anomalies that lead to the ridiculous split ticket system.  How would an ITSO card know you were splitting at Didicot unless you physically got off the train and swiped your card?
Many of these anomalies spring from the differences between the areas that were previously in the old Network South East Area and those outside it.
An ITSO card should also allow you pay the right fare for the train (i.e. off peak or super off-peak) without having to guess that you would be able to do this on your return journey when you were buying an outward ticket earlier in the day.
These issues were discussed extensively on this forum on http://www.firstgreatwestern.info/coffeeshop/index.php?topic=9296.0
« Reply #1 on: December 28, 2011, 14:24:08 »
I suspect ITSO will go the way of Oyster (Smartcard system used by passengers on Transport for London services) and only have single fares....
« Reply #2 on: December 28, 2011, 14:29:12 »
I expect you are right, but if the single fare is always half the return then that should not be an issue.
Andrew1939 from West Oxon
« Reply #3 on: December 28, 2011, 14:35:54 »
The ITSO system has a very flexible specification to enable it to be a multi-use card allowing for permits such as season tickets to be on board together with concessionary passes (senior bus cards are already ITSO even if the technology to use it is not in common use) and to carry cash for small transactions such as buying a single ticket or just a daily newspaper. Again as in the case of FGW (First Great Western)'s failure to invest in car parking facilities as Chiltern has, FGW is behind GoAhead that is using ITSO on its Oxford Bus company operations and has recently started to introduce them on its London Midland trains. The Oyster (Smartcard system used by passengers on Transport for London services) card, due to its age, has a much more limited scope for use and linking it to the ITSO specification seems to have been very difficult (and expensive).
« Reply #4 on: December 28, 2011, 14:40:01 »
But I can't see how evben a 'clever' card can predict what time one might return - so to deduct the 'right' return fare is not practical. I can't see anything on offer than single fares, ties to the time of touch-in.
Btline
« Reply #5 on: December 28, 2011, 14:49:51 »
Simplify the tickets then!
Make all singles half the price of a return (by lowering the singes, not raising the returns). Get rid of day tickets - re-use less likely on ITSO.
The evening peak should not exist/doesn't work as has been proved many times - it's purely a money spinner - so that should be axed at the same time, so if you touch in after 9.30am, you're charged the off peak fare -end of.
Get rid of splitting disadvantages by reducing the fares from points west of Didcot or introducing a zonal system.
How would First Class work?
« Reply #6 on: December 28, 2011, 15:07:48 »
The ITSO card works in a similar way to that of your current debit card when buying a ticket in that you first specify your ticket requirement before the fare is taken from the credit on your card. When in use as a season ticket, the conductor needs to have the technology to read the ITSO card and I suspect that current machinery of train conductors probably cannot cope with that. GoAhead and Stagecoach buses can now deal with ITSO cards but many bus operators in other parts of the country probably have not. I suspect that the high bus use in Oxford has made ITSO use viable (as is the investment by GoAhead and Stagecoach in modern bus fleets in Oxford).
« Reply #7 on: December 28, 2011, 15:25:27 »
Hmmm - that means going to a ticket office / machine before commencing your journey as now. The big benefit of Oyster (Smartcard system used by passengers on Transport for London services) is that you only need to do that to top-up your balance, with the touch-in & touch-out defining the ticket purchased from your balance - and I would expect ITSO to work the same way - hence only singles available, and the time of touch-in dictates the fare level.
Btline
« Reply #8 on: December 28, 2011, 16:47:09 »
I would imagine you could buy a ticket online and the "load" it at the station by touching in. This would end the current stupid situation when you have to insert your card, and if the machine feels like it, press in a code (fingers crossed it's not cold, otherwise that's difficult).
« Reply #9 on: December 28, 2011, 16:59:01 »
Heaven help you if you lise your card.... First thing someone might well do is to touch it ob a reader to see where they might be able to go.
No, I suspect only advance tickets might be bought that way. Plus season renewals maybe? Otherwise you buy by touching in & touching out, and the system works out your fare. But don't lose it!
Btline
« Reply #10 on: December 28, 2011, 17:06:22 »
Just superglue it to your wallet! Grin
« Reply #11 on: December 28, 2011, 18:21:16 »
For a PAYG (Pay as you go) functionality (like Oyster (Smartcard system used by passengers on Transport for London services)) you'd require the deduction of an entry charge at touch in, and an adjustment on touch out.  The entry charge needed to cover a national system would not be practical, so I strongly suggest that PAYG functionality will always be limited to discreet local areas.
« Reply #12 on: December 28, 2011, 21:17:37 »
If it were linked to your bankaccount, it wouldn't....
Btline
« Reply #13 on: December 28, 2011, 22:33:28 »
I believe the highest fare is about ^1000 at the moment. So if you touch in at Newquay or Kyle....
 Shocked
« Reply #14 on: December 28, 2011, 22:45:17 »
I am not sure why Oyster (Smartcard system used by passengers on Transport for London services) PAYG (Pay as you go) has to deduct a high fare and refund it anyway. Even Oyster allows this to go below zero, requiring only 1.90 I think to let you through a barrier.
If you have not got enough on your card then either you should have a credit allowance (personal to your account) or you should have to pay the excess to a ticket inspector or at the barrier.
Simple
